Webassist extensions and the last Dreamweaver
Thread begun 5/28/2021 8:34 am by Alexneg66 | Last modified 6/14/2021 9:06 am by Ray Borduin | 1481 views | 9 replies |
Alexneg66
I haven't used extensions with Dreamweaver in quite a while. What is the compatibility level with the latest version of Dreamweaver CC?
Everything is fully compatible with the latest version of Dreamweaver.
Alexneg66
Hi Ray, can you help me? Or is there a guide? I have tried with DMX to install my Webassist extensions but I was not able
Try using:
https://www.projectseven.com/products/ex-man/info.htm
If that doesn't work, provide a complete description of what errors you get and what your experience was and I can try to figure out what is going wrong.
Alexneg66
Thanks and one request
Hi Ray, thanks for the advice. I managed to install everything I could install. I sent you a private message. Thanks in advance.
I'm glad you got it working (see private message)
Alexneg66
Thanks Ray (see private message)
The mysqli server behaviors use mysqli instead of mysql. It is a completely different code base that works on the most recent versions of php. It stands for "MySQL Improved".
Alexneg66
the really question
Hi Ray,
thanks for your reply, I understood what "MySQLi Server Behaviours" does. My the really question is, if I have MySQLi server behaviours (in DataBridge v2), why I'd buy "MySQLi Server Behaviours"?
Thanks in advance
You don't have to buy MySQLi Server Behaviors if you own DataBridge v2. All of the functionality is included.
