i have form content repeat data 900 records.. than at insert multiple data it work till item recordcount 333.. when i do item 334 the items will not be inserted at insertMultipleRecords
Thread begun 10/20/2021 4:17 am by jpbosboom.60369949 | Last modified 10/26/2021 8:32 am by Ray Borduin | 1315 views | 7 replies |
jpbosboom.60369949
i have form content repeat data 900 records.. than at insert multiple data it work till item recordcount 333.. when i do item 334 the items will not be inserted at insertMultipleRecords. I made with <?php echo($wa_startindex); ?> visible the count. so item 333 will be pt into basket / item 334 not.
Your php.ini file has a setting for max form fields and data size. The variable names are:
max_input_vars
post_max_size
one or the other is hitting your upper limit at that many rows. You will have to adjust them to allow for a larger form.
jpbosboom.60369949
thanks, have to ask the hosting compagny. Anyway..the multiple insert, you can skip inserting when x is empty. Can it also be made when x is '0'
You would have to edit the code slightly by hand to do that, but it is certainly possible. If you attach your page I can take a look and suggest the line to change.
jpbosboom.60369949
i found out the following:
i told you at record count it stops inserting.. also if only one item is selected after number 333
Now i worked today at it and found out the folowing.
today i made an extra input field ( 4th) and after that the inserted stopped at 250..
So item 249 is being inserted , item 250 not.
maybe sowhere there is a limit 999/3 = 333 999/4 = 250
I attached txt file with the pagecode
webassist.txt
Create a page with:
phpinfo();
You will probably see that the max_form_fields setting is set to 500. (250 rows with 2 form fields per row)
jpbosboom.60369949
  Create a page with:
phpinfo();
nmax_form_fields setting is set to 500 > no such field
Anyway... recordset is 900 irems total.
Multiple record insert > i only inserting 2 items out of the 900.
As long as item number is below the items number 250, all selected will be inserted.
BUT if i insert items 249 and i.e. 254. only one , the first one is inserted.
The work around is to increase the max form fields number in the php.ini file.
