Fatal error: Class 'mysqli' not found
Thread begun 12/21/2021 9:06 am by Jamie | Last modified 12/21/2021 10:10 am by Ray Borduin | 283 views | 2 replies |
Jamie
Hey Ray
Have got an error on a login page
Fatal error: Class 'mysqli' not found in /home/sites/8a/4/43569c2086/public_html/Connections/DBConnection.php on line 39
Not sure what may be causing this?
Cheers
What php version are you running? The error implies that mySQLi isn't installed. This is a hosting issue, so you would probably have to contact them to get mysqli installed on the server. If you look at the phpinfo() result, it will list mysqli if it is installed properly.
Jamie
Thanks Ray
On with the hosting provider and seems to have been an error at their end
Thanks for the steer
Jamie
