Link from an image
Thread begun 1/02/2022 6:32 am by john70964 | Last modified 1/06/2022 10:40 am by Ray Borduin | 2661 views | 9 replies |
john70964
Link from an image
Hello Ray
I have been having some problems creating links on pages so decided to go back to basics.
To create pages with links what could be better than to use the
DW Top menu bar - WebAssist - Database - DataAssist Pages.
So there I created The pages Search - Results - Details and all works very well.
One item I wish to change is the dynamic link to go from Results to Details. This is a Magnifying Glass and I wish to use a Field such as the record number or an image.
I tried to adapt the magnifying glass code but could not get this working.
Can you please provide a sample?
I am attaching files
Many thanks
John
Just create a link with:
<a href="mydetails.php?RecNo=<?php echo($WADAboats->getColumnVal("RecNo")); ?>">link text here</a>
john70964
Hi Ray,
This is most peculiar in boat-details.php I have directed the link to boatenquiry_insert.php
Link is now
<a href="Enquiries/boatenquiry_insert.php?RecNo=<?php echo($WADAboats->getColumnVal("RecNo")); ?>">
When I run index.php/boat-details.php the link text disappears along with anything below the link.
(I would prefer a button working).
I am attaching the file.
John
Your recordset is named: $WADAboats_details
not: $WADAboats
So the getColumnVal() reference has to be updated to use a recordset name that is defined on the page.
john70964
Thanks Ray the link now works fine.
I did try to adapt the link code into the button but would you believe no joy?
Can you please show me what it should be?
I have attached the file.
Many thanks
John
<button type="button" onclick="document.location.href='Enquiries/boatenquiry_insert.php?RecNo=<?php echo($WADAboats->getColumnVal("RecNo")); ?>'">click here</button>
john70964
Hi Ray
I have pasted the code sent
<button type="button" onclick="document.location.href='Enquiries/boatenquiry_insert.php?RecNo=<?php echo($WADAboats->getColumnVal("RecNo")); >'">click here</button>
in the page, but it is not working also seems to introduce a syntax error at line 336 and lose some of the code when I paste it in.
I am attaching a picture and the file.
Regards
John
That isn't the same as the code I provided.... it should be:
<button type="button" onclick="document.location.href='Enquiries/boatenquiry_insert.php?RecNo=<?php echo($WADAboats->getColumnVal("RecNo")); ?> >'">click here</button>
You have:
Make sure you copy from the forum post on the web and not your email. Email clients can change the text and make it unusable.
john70964
Hi Ray,
I copied the code from above but still have a problem.
I have created 3 attachments which should show the result.
Image 1 shows wth new code
Image 2 shows without new code
Many thanks
John
You have button code:
but your recordset is named: WADAboats_details
So the code should be:
$WADAboats_details->getColumnVal("RecNo")
