Best Way To Proceed
Thread begun 1/06/2022 3:45 am by yogastudents362523 | Last modified 1/13/2022 9:28 am by Brant | 1377 views | 3 replies |
yogastudents362523
Best Way To Proceed
Hello,
This is not about an error, so no real need--or urgency to--respond.
I do not like amending code for my needs or purposes, because only being a relatively unfamiliar amateur, it leads to errors. The "while" statement the MySQLi extension placed on my page did not give me enough control over the output. I found that I instead needed a do-while loop. I first had to create my solution procedurally elsewhere, and then gradually adapt to object-oriented.
Here is the solution I came up with:
<?php if ($mySaturdayClasses->TotalRows > 0) { // Show if mysqli recordset not empty ?>
<p><span class="cancelledtext">Classes held on:
$previous = date('M');
echo "<strong>";
echo $previous;
echo "</strong>";
$wa_startindex = $mySaturdayClasses->Index;
do {
if (!(date('M', strtotime($mySaturdayClasses->getColumnVal("classdate"))) == $previous))
echo "<strong>";
echo "| ";
echo date('M', strtotime($mySaturdayClasses->getColumnVal("classdate")));
echo "</strong>";
$previous = date('M', strtotime($mySaturdayClasses->getColumnVal("classdate")));
echo " " . date('jS', strtotime($mySaturdayClasses->getColumnVal("classdate")));
<?php $mySaturdayClasses->moveNext();
} while (!$mySaturdayClasses->atEnd()) ; ?>
<?php $mySaturdayClasses->moveFirst(); //return RS to first record
unset($wa_startindex);
unset($wa_repeatcount); ?>
</span></p>
<?php } // Show if mysqli recordset not empty ?>
That solution was based on this query (generated by MySQLi):
$mySaturdayClasses = new WA_MySQLi_RS("mySaturdayClasses",$mysqli_workshops,0);
$mySaturdayClasses->setQuery("SELECT * FROM workshops.saturdayssundays WHERE (saturdayssundays.classdate BETWEEN (DATE_ADD(CURDATE(), INTERVAL 0 MONTH)) AND (DATE_ADD(CURDATE(), INTERVAL 5 MONTH))) AND (WEEKDAY(saturdayssundays.classdate)=5) ORDER BY saturdayssundays.classdate");
$mySaturdayClasses->execute();
I just want to know if there was a way to achieve the same end ENTIRELY using WebAssist tools, and that I somehow missed. I have some more complex tasks I must accomplish that will appear later in this project, and if I can avoid hand-coding to minimize my risks, that is what I would prefer.
Thank you,
KAB
yogastudents362523
If it helps you can see the solution I generated in the location at the URL in the private area.
Thank you.
You need some hand code, but you can certainly do the loop with the webassist repeat region instead of your for loop... something like:
<?php if ($mySaturdayClasses->TotalRows 0) { // Show if mysqli recordset not empty ?>
$previous
date('M');
 <strong><?php echo $previous?></strong>
$wa_startindex
0;
while(!
$mySaturdayClasses->atEnd()) {
$wa_startindex $mySaturdayClasses->Index;
if (!(date('M'strtotime($mySaturdayClasses->getColumnVal("classdate"))) == $previous)) {
<strong>|
<?php echo date('M'strtotime($mySaturdayClasses->getColumnVal("classdate"))); ?>
</strong>
  $previous
echo
" " date('jS'strtotime($mySaturdayClasses->getColumnVal("classdate")));
  $mySaturdayClasses
->moveNext();
unset(
$wa_repeatcount);
</span></p>
<?php // Show if mysqli recordset not empty ?>
yogastudents362523
Hello,
Thank you very much for your help, yesterday.
KAB
