If/Else for goto pages
Thread begun 1/08/2022 8:14 am by birdscreen398247 | Last modified 1/12/2022 12:58 pm by Ray Borduin | 2741 views | 10 replies |
birdscreen398247
You created this if/else scenario for me, but now I have three choices instead of two.
<a href="PORC_Member_Round_<?php echo($rsBatchRecords->getColumnVal("sendto_second_round")?"2":"1"); ?>_Ballot.php?record_number=<?php echo ($rsBatchRecords->getColumnVal("record_number")); ?>"><?php echo($rsBatchRecords->getColumnVal("record_number")); ?></a>
The new choices are:
If the field “ebird_expedited” is true, then go to PORC_Member_ebird_Ballot.php
Else if “sendto_second_round” is true, then go to PORC_Member_Round_2_Ballot.php
Else go to PORC_Member_Round_1_Ballot.php
How should that be written?
Single line IF statements get complex after a couple. I'd break it out into multiple IF statements above like:
$pageName
"PORC_Member_Round_1_Ballot.php";
if (
$rsBatchRecords->getColumnVal("sendto_second_round")) $pageName "PORC_Member_Round_1_Ballot.php";
if (
$rsBatchRecords->getColumnVal("ebird_expedited")) $pageName "PORC_Member_ebird_Ballot.php";
<a href="<?php echo($pageName); ?>_Ballot.php?record_number=<?php echo ($rsBatchRecords->getColumnVal("record_number")); ?>"><?php echo($rsBatchRecords->getColumnVal("record_number")); ?></a>
birdscreen398247
Using this code:
$pageName = "PORC_Admin_Batch_Round1_Form.php";
if ($rsBatchRecords->getColumnVal("send_to_second_round")) $pageName = "PORC_Admin_Batch_Round2_Form.php";
if ($rsBatchRecords->getColumnVal("ebird_expedited")) $pageName = "PORC_Admin_Batch_eBird_Form.php";
<a href="<?php echo($pageName); ?>?record_number=<?php echo ($rsNewRecords->getColumnVal("record_number")); ?>"><?php echo($rsNewRecords->getColumnVal("record_number")); ?></a>
It always goes to the first page "PORC_Admin_Batch_Round1_Form.php"
It does not appear to be parsing the IF statements correctly.
Both "send_to_second_round" and "ebird_expedited" are TinyInt (1/0) fields.
Please attach the page so I can look at the code to see what might be wrong.
birdscreen398247
See attached file.
The code that updates the url isn't on the page you attached.
birdscreen398247
I don't understand. What code? What url?
This code:
$pageName
if (
$rsBatchRecords->getColumnVal("send_to_second_round")) $pageName "PORC_Admin_Batch_Round2_Form.php";
if (
$rsBatchRecords->getColumnVal("ebird_expedited")) $pageName "PORC_Admin_Batch_eBird_Form.php";
Is not on the page you attached. I think you attached the wrong page? It looks like the recordset name is different on this page as well.
birdscreen398247
Here is the file again. PORC_Admin_Non_Batch_Records.php
birdscreen398247
I see that the recordset name in the If statements was wrong. I corrected that and now I get URL Not Found.
