mySql Update Record Behavior
I created a simple form to update some records using the WebAssist MySqli Update Record wizard.
See attached file.
Instead of updating the record, it blanks all of the fields!
What did I do wrong?
See attached file.
You have the fields bound to $_GET values but probably changed your form to "post" after application.... The bound values have to be updated to $_POST instead of $_GET.... you can probably just do a find/replace.
