Show Region
Thread begun 1/09/2022 11:17 am by birdscreen398247 | Last modified 1/09/2022 2:21 pm by Ray Borduin | 234 views | 1 replies |
birdscreen398247
Show Region
I want to show or hide two fields based on a SecurityAssist rule.
I want batchdate (a Select box) to show if $rsDecisions->getColumnVal("batch_date" is null or blank.
(batch_date_select_hide)
I want batch_date (a readonly text field) to show if $rsDecisions->getColumnVal("batch_date" has data.
(batch_date_show)
The rules I set up are:
case "batch_date_select_hide":
$comparisons[0] = array(TRUE, "".($rsDecisions->getColumnVal("batch_date")) ."", 1, "\"\"");
break;
case "batch_date_show":
$comparisons[0] = array(TRUE, "".($rsDecisions->getColumnVal("batch_date")) ."", 5, "01/01/1901");
break;
The fields on the form are:
<p style="margin-left: 20pt;text-indent: 0pt;text-align: left;">
<?php if(WA_Auth_RulePasses("batch_date_select_hide")){ // Begin Show Region ?>
<select name="batchdate" class="TextBox" id="batchdate" >
while(!$rsBatchDates->atEnd()) { //dyn select
<option value="<?php echo($rsBatchDates->getColumnVal("Batch_Date")); ?>"<?php if (!(strcmp($rsBatchDates->getColumnVal("Batch_Date"), ($rsBatchDates->getColumnVal("Batch_Date"))))) {echo "selected=\"selected\"";} ?>><?php echo($rsBatchDates->getColumnVal("Batch_Date")); ?></option>
$rsBatchDates->moveNext();
} //dyn select
$rsBatchDates->moveFirst();
</select>
<?php } // End Show Region ?>
<?php if(WA_Auth_RulePasses("batch_date_show")){ // Begin Show Region ?>
<input name="batch_date" type="text" id="batch_date" value="<?php echo($rsDecisions->getColumnVal("batch_date")); ?>" readonly/>
</p>
When I run the page. Neither field shows up and everything else on the page below that code is not displayed.
Please help.
Frank
You can't do security assist rules based on recordset values.
Use the server behavior "webassist" -> "Utilities" -> "Show Region Utility"
That will allow you to do a show if based on a recordset value on the page.
