How can I install "Data Bridge v2"
Thread begun 1/11/2022 1:40 am by Brunco53 | Last modified 1/11/2022 9:46 am by Ray Borduin | 809 views | 1 replies |
Brunco53
Hello
I would like to apply "Data Bridge v2".
I am using Dreamweaver version 21.2.
How can I install "Data Bridge v2" without an extension manager?
Best Regards brUNO
Hello
In the meantime I was able to install the extension on my Dreamweaver account.
Unfortunately I can not connect to the database, I get the following error message:
your php server doesn't have the mysql module loaded or you can't use the mysql_(p)connect functions
Is there any way to solve this problem?
This is usually an issue with the Dreamweaver server settings and if/how you set up your "Testing Server".
The testing server has to be configured properly in order to connect to the database.
