insert record if it doesn't already exist
Thread begun 1/11/2022 9:07 am by birdscreen398247 | Last modified 1/11/2022 1:33 pm by Ray Borduin | 1076 views | 3 replies |
birdscreen398247
I want to insert a record only if the record does not already exist.
I found a thread on this topic, but could not parse out the code that I need.
Here is my InsertQuery code
if (($_SERVER["REQUEST_METHOD"] === "POST") && (isset($_SERVER["HTTP_REFERER"]) && strpos(urldecode($_SERVER["HTTP_REFERER"]), urldecode($_SERVER["SERVER_NAME"].$_SERVER["PHP_SELF"])) > 0) && isset($_POST)) {
$InsertQuery = new WA_MySQLi_Query($siteguide2018);
$InsertQuery->Action = "insert";
$InsertQuery->Table = "PORC_decisions";
$InsertQuery->bindColumn("record_number", "s", "".((isset($_POST["record_number"]))?$_POST["record_number"]:"") ."", "WA_DEFAULT");
$InsertQuery->saveInSession("");
$InsertQuery->execute();
$InsertGoTo = "PORC_Admin_New_Records.php";
if (function_exists("rel2abs")) $InsertGoTo = $InsertGoTo?rel2abs($InsertGoTo,dirname(__FILE__)):"";
$InsertQuery->redirect($InsertGoTo);
I only want it to run if a record with the record_number field does not already match the record_number field on the form.
Note: the record_number field is a Primary field. So right now, if I try to submit the page and the record_number exists, all I get is a SQL error message.
So if there is a way to use the primary field property in this procedure, maybe that is the simplest solution.
You could create a recordset filtered by the record number and then use the Recordset Empty trigger for the insert. Just make sure the recordset is above the insert in the code.
birdscreen398247
I know how to create the recordset, but what is the code for Recordset Empty?
If my recordset is rsRecordset1, then what do I put in front of the update query?
If you add the recordset, then open the Insert server behavior, then the trigger dropdown list should have "Recordset Empty" as an option.
