cannot load "presenters_login_update.php"
Thread begun 1/18/2022 8:53 pm by yogastudents362523 | Last modified 1/19/2022 1:51 pm by Ray Borduin | 1622 views | 3 replies |
yogastudents362523
As you recommended, I have created a "presenters_switchboard.php" page from which my Presenters will eventually be able to access any other relevant Page. I am presently using it to create then test all other pages required.
I clicked on the appropriate link to go and examine and style the presenters_login_update.php page that Security Assist had created. This would not allow me to access it, instead batting me over to the presenters_login.php page to log in; and then into an endless loop of inaccessibility.
I used SecurityAssist to recreate the page in case there had been an error. Same thing.
What do I need to do to allow both myself and Presenters to access those pages?
I attach the offending page hereto.
And full URLs, plus login credentials, so you can log in and test for yourself will be in Private Area of upcoming "response".
Thank you,
KAB
yogastudents362523
Further details in private area under:
Thank you
It looks like you have overwritten the webassist/security_assist/helpergroupsrulesphp.php file and don't have any rules defined.
I had updated that file to add the missing rules for you, but you must have not downloaded the file after I made changes and overwritten my changes.
Also your login update page is using the rule: "Logged in to presenter_data"
But that rule isn't defined either.
I went in and updated that file again. Please download it so you don't keep overwriting it removing the rules I've defined for you.
yogastudents362523
Hello,
I did carefully download the relevant file, earlier.
So I got rather puzzled.
Rather than relying on DreamWeaver to "get" all additional files, I have this time d/led manually (using WinSCP).
There are in fact two webassist directories.
One is at the root as just /webassist/
The other is located in that working directory of /presenters/webassist/
Both contain a SecurityAssist folder.
I am now praying that I have the right file, because I have downloaded both on this occasion; and also created a backup of each up there on the server, just in case.
I hope that will cover all future eventualities, and apologise for any error I might have made.
I have downloaded . But I am reckoning that it is the presenters/webassist that is the relevvant one, for it has considerably more files in it than the other.
Thank you. ​
And I am again sorry for the inconvenience.
