Select upload folder
Thread begun 1/29/2022 7:43 am by randyrie405335 | Last modified 1/31/2022 12:19 pm by Ray Borduin | 1044 views | 3 replies |
randyrie405335
Do you have a widget or extension that will allow the user to select a folder to upload to (see my attached example of what I have in mind...)?
If not, is this even possible?
Just save their selection in the session and use it as the upload folder value in the upload server behavior. You could just use the upload folder from the POST in the upload server behavior as well if it is part of the same form.
randyrie405335
Thanks Ray for your suggestion albeit I'm not a coder and have no idea how to write this... that's why I was asking if there was a GUI/widget/extension I could use that I could use. Can you direct me to a site where something similar is being used so I can get an idea how to code it?
Just use the standard File Upload server behavior and where it asks for the upload folder, specify the POST value.
