Time format on form
Thread begun 2/08/2022 9:21 am by birdscreen398247 | Last modified 2/08/2022 10:15 am by Ray Borduin | 709 views | 1 replies |
birdscreen398247
Time format on form
I have a Time input field on a form. It is in HH:MM AM/PM format.
I have been informed by an iPhone user, that when they try to input the time, it does not allow them to type a time, but instead it presents a dropdown box to select the hour and minutes. However, it is in 24-hour format, so it triggers the alert on the form that it is an invalid time.
The time field works fine on other platforms.
Is there a way to code for that?
I did some web searching, and it appears that the time format depending on operating system locale. This means you can't control it.
The only solutions would be to use a custom time script that you have more control of, or loosen up your validation to allow 24 hour format.
