dynamic dates are correct on the page but not when written to a .ICS file
Thread begun 2/21/2022 9:38 am by Mags | Last modified 3/16/2024 3:43 pm by Sweens | 2319 views | 6 replies |
Mags
Hi Ray, got a bit of a strange issue - I have an events page which shows dates and times of events from the database, along with an "add to calendar" button which writes the info to a .ICS file which users can then open to add the event to Outlook etc (I'm using the script from https://gist.github.com/jakebellacera/635416). The times display correctly on the page and I can see when using Inspector that the dates & times in the submission forms for the button are also correct, however when I open the .ICS file an hour is being added onto the given time (although the first one in the list does work properly for some reason!) I'm sure it must be due to daylight saving time as we're currently on winter time in the UK, however I've tried various strtotime syntax and it doesn't make any difference. Could you possibly take a look for me? I can give you a URL if easier but have attached the relevant files.
I think the issue would be on the page: download-ics.php
I may be able to spot it with that file, but the best way to allow me to debug would be to give me a URL and FTP access to debug the live pages and see what is going on that way.
Mags
That would be great thanks, much appreciated - details in PM.
*Update: I got it working by adding the following line in the ICS file at line 149:
private function format_timestamp($timestamp) {
$dt = new DateTime($timestamp);
$dt->setTimezone(new DateTimeZone('GMT-1'));
return $dt->format(self::DT_FORMAT);
Strangely UTC or GMT didn't work but the above does. I note that PHP doesn't advise using GMT-1 as it's only meant for backwards compatibility, so I don't know if there's an alternative I could use? Not urgent for now since it's working, so only if you have a spare minute!
I think you should be good with that code. You could probably replace the GMT reference with a time zone from here:
https://www.php.net/manual/en/timezones.php
but I'd probably leave well enough alone if it is working.
Sweens
Hi Mags
Is there an chance I could have a copy of your page, so I could edit it for a charity site I run? I've been trying to get this working, but I'm not a coder and have no idea what I should be doing! Please see pm
Chris
Mags
Hi Sweens, sorry I didn't reply sooner - for some reason I didn't get an email telling me someone had replied to this thread, I just happened to spot it whilst browsing.
I've attached the pages in question, hope it helps. I've stripped out a lot of the stuff on the Events page that you don't need. Note I don't actually use this page any more, and it's almost 2 years since Ray helped me with it, so I don't really remember that much about it! If I can be of any further help though, let me know.
Sweens
Hi Mags
So grateful, thanks very much.
I hadn't subscribed to the thread, so didn't see this until I tried to do the ics thing again. I'll let you know how I gt on.
Thanks again
UPDATE - I've managed to get it working for individual events, as in your example. My next step is to try and get it to insert all events in on go.
I'm so grateful - thanks again.
Chris
