Multiple recordsets?
Thread begun 2/28/2022 9:50 am by birdscreen398247 | Last modified 3/23/2023 4:53 pm by Ray Borduin | 3021 views | 11 replies |
birdscreen398247
I have a table with the following fields: Birder_ID, CountType, CountCounty, Quantity (plus some other fields unrelated to this question).
I have a form that lists 67 counties and the Quantity that goes with each. In other words, the Quantity that would go in the Adams county field would be the Quantity from the table that has Birder_ID = ? AND CountType = 'Life' AND CountCounty = 'ADAMS' (where ? is a session variable birder_ID).
I could create 67 recordsets to retrieve this data, but is there a simpler way to do it?
Yes... You can use Count() and Group By statements in your recordset to get counts for each county.
birdscreen398247
There is only one record per birder per county, so I don't think Count() is appropriate here.
All I want to retrieve is the number in the Quantity field.
Sample records:
Birder_ID CountType CountCounty Quantity
23 Life ADAMS 245
23 Life MONTGOMERY 156
23 Life WARREN 212
34 Life ADAMS 175
etc.
So on the form for the birder with an Birder_ID of 23, I want ADAMS: (and a form text field with, in this case, 245)
If the birder is #34 then the number after ADAMS: would be 175, etc.
You can create a recordset that returns all of the results and then filter to show individual rows like:
$RecordsetName->filterResults([["Birder_ID",23],["CountCounty","ADAMS"]]);
birdscreen398247
Three questions.
1. I could not find a PHP command "filterResults" online. Is this a php command or what?
2. If the recordset already filters on the Birder_ID, do I need the second set of brackets in the following line of code?
$rsPALifeList->filterResults([["CountCounty","ADAMS"]]);
3. Then, using that filter, how do I retrieve the value of the Quantity field?
Once you apply the filter you can use ->getColumnVal("Quantity");
It isn't a standard php function. It is a special webassist recordset function.
birdscreen398247
filterResults function
I just tried the following code and I get a syntax error message on the first line ("$rsWRSRoutes->filterResults([["RouteNumber","015"]]);").
$_SESSION["compilerID"] = $rsWRSRoutes->getColumnVal("Compiler");
I do have rsobj.php linked to the page.
Where is the syntax wrong?
Is that the correct recordset name? $rsWRSRoutes
Please attach the page so I have some context otherwise I'm grasping at straws.
birdscreen398247
This is just a test page.
I am trying to figure out how to pick out a single record from a recordset without creating a new recordset.
In the sample case, I want to select a specific route number and display data from that record.
I will eventually have multiple routes to click on to display data from each one as a popup.
For now I just want to display on the screen the CompilerID just to show that I retrieved the correct data.
So I just need to get the syntax right.
The offending code is Line 49
You may just need:
@session_start();
after line 7.
If that doesn't work I'll probably need a URL and FTP access to fully debug.
