addfilter
Thread begun 4/06/2022 11:07 am by birdscreen398247 | Last modified 4/06/2022 2:46 pm by Ray Borduin | 2854 views | 10 replies |
birdscreen398247
addfilter
On line 21 of the attached file, I am trying to filter on two fields, one of which involves a substring.
I am getting
"Recoverable fatal error: Object of class WA_MySQLi_RS could not be converted to string in /home/w72w9xoqmrbx/public_html/webassist/mysqli/queryobj.php on line 340."
What is the correct syntax for what I am trying to do?
On line 19 you have:
$UpdateQuery->Table = $rsTemp;
That should be a table name like:
$UpdateQuery->Table = "PORC_decisions";
birdscreen398247
Whoops, I forgot I tried a different approach earlier and forgot to change it back.
I changed the table name, and no longer get any errors, but it is not updating the table.
Is my syntax correct on the substring, etc.
I am trying to extract 2020 out of 1234_2020_1234 and also filter on PORC_class great than "".
$UpdateQuery->addFilter("substring(record_number,6,4)", "=", "s", "".((isset($_POST["UpdateYear"]))?$_POST["UpdateYear"]:"") ." AND PORC_class>''");
No, that is not correct.
addFilter(column,comparison,type,value);
So the first argument should be a column name.
You can't add an AND to do multiple column comparisons you should add multiple addFilter() rows.
birdscreen398247
So is there anyway to filter on substring(record_number,6,4)?
Yes, that would be the filter value. You have it in the place of the column name.
birdscreen398247
So...
$UpdateQuery->addFilter("record_number", "=", "s", "".substring(record_number,6,4) = ((isset($_POST["UpdateYear"]))?$_POST["UpdateYear"]:"");
That doesn't look right. I'm not sure what you are trying to do with the value:
Where does the UpdateYear posted value come in?
I would think it would be something like:
$UpdateQuery->addFilter("record_number", "=", "s", "".substring(record_number,6,4) ."");
birdscreen398247
I want to update the records where substring(record_number,6,4) is equal to the $_POST["UpdateYear"]
Not filter on the whole "record_number" field.
That is easily done in Visual Basic for Access, but sql doesn't seem to accommodate that.
I think I'll need a phone call to understand what you are trying to do.
I'm starting to understand though... It might be:
$UpdateQuery->addFilter("substring(record_number,5,4)", "=", "s", "".((isset($_POST["UpdateYear"]))?$_POST["UpdateYear"]:"") ."");
