Local test server session variable issue
Thread begun 4/18/2022 12:08 am by evansg7124312885 | Last modified 4/18/2022 11:41 am by Ray Borduin | 318 views | 1 replies |
evansg7124312885
Good morning,
Initializing PS 4 onto a MAMP server environment and ran into this on step 2. Since this is a local machine, there is no administrator to call. I am guessing that this is line within my PHP.INI configuration, but so far, have not found a good match to the problem. Can you tell me what this step in the installation is looking for or where off this problem I should look to correct? Thanks in advance. Machine is running Windows 10, MAMP version is 4.2.0 and says it is current.
Usually this is an issue with the session_save_path in your php.ini file being set to a non-existent directory or one with inadequate permissions.
