emails not being sent
Thread begun 4/22/2022 6:29 am by msmoose2400634 | Last modified 4/27/2022 4:30 pm by Ray Borduin | 2308 views | 6 replies |
msmoose2400634
I have a form ContactUs.php and a ContactUs_Sent.php and I used the WA Server Behaviour "Sent Email"; there are 3 fields on the form;emailaddress; subject; messagebody.and a "Sendbutton". The ContactUs.php when the Sendbutton is pressed the system navigates to the correct page; contactus_sent.php; but no email is received. I have a screen copy of the Server Behavioiur. I checked to make sure that all of the files where uploaded to the testing server and I also hardcoded both the "busemail" (which is coming from a recordset)nand the emailadddress in thee Server Behaviour. I also changed the POST to GET; and nothing seems to work.http://mussolinetestserver.site/contact/contactUs.php
Some email servers will not send emails that aren't FROM a valid email address from that server. Try setting the FROM to an email address like:
webmaster@yourdomain.com (and make sure it is a valid email address).
It could also be that the recordset you are using for the TO address isn't working properly.
I'd try getting it working with a hard coded TO and FROM and then change them to dynamic values one at a time to narrow down the problem.
msmoose2400634
The from email address is coming from a visitor on the form who is putting their email address is the form. So it can not be an email that is coming from the server. Also I know that the email server does accept this type of email because I have been using it for the last 10 years on the current websites using Dreamweaver and the Dreamweaver toolkit; The recordset is correct as i have checked that it is a valid email. Also did harcode both the from email address and the To email address to trouble shoot before I submitted this post to you.
It still didn't send when you hard-coded the from and to? Even if the email is coming from the person filling out the form, I'd use a local email address for the FROM and use the email address in the form as the REPLY_TO. That would improve deliver-ability.
I'll probably have to debug this one live. Can you send me FTP access?
msmoose2400634
Okay, I put a "hidden field" in the form which is the business email address coming from a recordset (this is who the email address is going to), and still no email.
Your <form> tag has the action set to: /contact/contactUs_sent.php
That makes the form post directly to that page and doesn't give the email a chance to send.
You need to remove the form action so the page submits to itself and then use the email redirect to go to the sent page.
msmoose2400634
Thank you Ray, obviously I didn't realize that the server behaviour (Send Email) would navigate to the Email Sent.php page, but now I do. Karen
