dataassist search
Thread begun 5/05/2022 3:48 pm by msmoose2400634 | Last modified 5/06/2022 1:31 pm by Ray Borduin | 1732 views | 7 replies |
msmoose2400634
dataassist search
I have a page (http://mussolinetestserver.site/admin/EditAllMembersList.php) that list our current members. When a member's name is clicked the member's unique id (persSeq) is passed in the URL; this page should open displaying the member's information http://mussolinetestserver.site/admin/EditByStaffProfilePage.php?persSeq=678
but I get an error message "Fatal error: Uncaught Error: Call to a member function fetch_fields() on bool in /home3/q300119/mussolinetestserver.site/webassist/mysqli/rsobj.php:219 Stack trace: #0 /home3/q300119/mussolinetestserver.site/admin/EditByStaffProfilePage.php(26): WA_MySQLi_RS->execute() #1 {main} thrown in /home3/q300119/mussolinetestserver.site/webassist/mysqli/rsobj.php on line 219"
I have tried it to different ways; one using
mySQLi Search
and a recordset rs_member
SELECT *
FROM v_MemberProfile
WHERE persSeq = colname (Name=Colname; Type=Integer; Default -1, Runtime Value=<?php echo ($_GET['persSeq']); ?>
Maybe the connection isn't working or is too low on the page? Can you attach the page? I can see if I can spot the problem.
msmoose2400634
Thank you!
I have attached the page that list all of the members (http://mussolinetestserver.site/admin/EditAllMembersList.php); and the page that when the user clicks on the name it opens this page (http://mussolinetestserver.site/admin/EditByStaffProfilePage.php?persSeq=790) BTW the correct persSeq is being passed to the URL.
What happens when you run this query in phpMyAdmin:
SELECT v_MemberProfile.* FROM v_MemberProfile WHERE v_MemberProfile.persSeq = -1
It looks like the parameter didn't get set right. on line 24 you have:
$rs_member->bindParam("i", "".(isset($_GET[''])?$_GET['']:"") ."", "-1"); //WAQB_Param1
It looks like it should be:
$rs_member->bindParam("i", "".(isset($_GET['persSeq'])?$_GET['persSeq']:"") ."", "-1"); //WAQB_Param1
msmoose2400634
I made the changes and see that I did forgot to enter the url variable that I wanted to pass; but I still get this error:
Fatal error: Uncaught Error: Call to a member function fetch_fields() on bool in /home3/q300119/mussolinetestserver.site/webassist/mysqli/rsobj.php:219 Stack trace: #0 /home3/q300119/mussolinetestserver.site/admin/EditByStaffProfilePage.php(25): WA_MySQLi_RS->execute() #1 {main} thrown in /home3/q300119/mussolinetestserver.site/webassist/mysqli/rsobj.php on line 219
I have attached my modified page
try adding this before line 25:
die($rs_member->debugSQL());
What is the result?
msmoose2400634
when I ran the script phpMyAdmin and this was the result:: MySQL returned an empty result set (i.e. zero rows). (Query took 0.0060 seconds.)
I add the line die($rs_member->debugSQL());
and two things happened:
#1) the recordsset server behaviour disappeared in the left panel but the code was still in the page
#2) this is what was displayed when I clicked on the persons name and the EditByStaffProfile.php
SELECT v_MemberProfile.* FROM v_MemberProfile WHERE v_MemberProfile.persSeq = 789 LIMIT 1
I did some research and found that there is a bug where Prepared statements don't work in MySQLi when using views in some versions of MySQL.
If you add this:
$rs_member->Prepared = false;
Then it should allow the recordset to load properly. This will only be necessary when your recordset uses ->bindParam() and it uses a view and not a standard table.
I've added the change to your recordset since I found FTP information and it seems to have fixed the page.
