Deprecated: Array string offset access syntax curly braces deprecated
Thread begun 6/10/2022 6:04 am by kost36 | Last modified 6/20/2022 10:31 am by Ray Borduin | 3931 views | 15 replies |
kost36
Hey Ray
Suddenly I get that error
Deprecated: Array and string offset access syntax with curly braces is deprecated in /home/pekkeux/public_html/webassist/mysqli/rsobj.php on line 150
Deprecated: Array and string offset access syntax with curly braces is deprecated in /home/pekkeux/public_html/webassist/mysqli/rsobj.php on line 152
Deprecated: Array and string offset access syntax with curly braces is deprecated in /home/pekkeux/public_html/webassist/mysqli/rsobj.php on line 189
Deprecated: Array and string offset access syntax with curly braces is deprecated in /home/pekkeux/public_html/webassist/mysqli/rsobj.php on line 191
I read in older supporting answers and reinstalled MySQLi_108 but it seems not to be fixed... Am I doing something wrong
Install the latest version of databridge and then update any recordset on your site. That will overwrite the rsobj.php file with the latest version and fix this issue.
kost36
What do you mean with update databridge? The only i use is MySQLi Server Behaviors
Sorry, update MySQLi Server Behaviors. DataBridge includes MySQLi Server Behaviors, so updating either should work.
kost36
Didn't fix it.
Steps:
Downloaded MySQLi_108.zxp
Deleted the previous version
Reset activation
Installed it again
You have to open and re-apply one of the recordsets on your page to overwrite the rsobj.php file. Then you have to upload the updated file.
kost36
Hey Ray, all done and the error disappeared but know I am getting
Call to a member function fetch_fields() on bool to every link (local and remote)
Version of rsobj.php 2.49 both local and remote
also from acquired speed in my account on your page I have written my e-mail as kost36@gmail.gr instead of kost36@gmail.com
I tried to change it but it doesn't allow me this option. Could it be possible you to change it ?
thank's
That error sounds like an issue with the connection or recordset query. I'd probably need to debug it with FTP access.
You had two accounts and the other email address was associated with another account. That is why you couldn't update it. I've merged the two accounts. You may have to do a forgot password to reset the password if you don't know the password for the other account.
kost36
Thank's for e-mail change
Please include a url and steps to see the issue live.
