purchase page reload issue
Thread begun 7/03/2022 11:48 am by yogastudents362523 | Last modified 7/05/2022 9:44 am by Ray Borduin | 2416 views | 6 replies |
yogastudents362523
purchase page reload issue [Partly Resolved]
Hello,
This is a much edited post. I resolved some issues.
Only issue now is I cannot see how to place a dedicated 'remove' button by each individual item placed in the shopping cart.
The only way I can see to "delete" one is to insert a quantity of '0', and then to push update.
Users stay on the page when "Add-To-Cart" button is pused, so they can add other items; or else remove ones added..
Links to page concerned in private area.
Thank you.
KAB
yogastudents362523
under
There is a remove link that only appears on mobile devices. You can update it to always show by removing a class from the link. Find the code:
html:
<p class="eC_ItemRemove_Link max_tablet"><a href="#" onclick="waec_update('Remove','festival_classes_Quantity_165695418226391927',this);">Remove</a></p>
Then remove the "max_tablet" class. That will make the link always appear in the cart.
yogastudents362523
Hi
I tried removing that class. The line (312) now reads:
<p ><a href="#" onclick="waec_update('Remove','festival_classes_Quantity_<?php echo $festival_classes->DisplayInfo("WAUID"); ?>',this);">Remove</a></p>
It did not have the required effect? The remove possibility does not appear?
Thank you.
PS Just to be clearer, I also tried
<p class="eC_ItemRemove_Link"><a href="#" onclick="waec_update('Remove','festival_classes_Quantity_<?php echo $festival_classes->DisplayInfo("WAUID"); ?>',this);">Remove</a></p>
The link is appearing and working for me in my tests. It is right there underneath the item name in the cart.
yogastudents362523
Apologies.
The table you auto-create for the cart has a complete header / section that says:
<th class="eC_FormItem desktop_only">Remove</th>
So I was (naturally??!!!) expecting something to show up there in the relevant <td></td> sections in the table, which stubbornly remained blank!!!
I did not even think to look where you say it is, and that I now see it!!
I can style and place it more appropriately now I have observed it.
My fault, sorry.
And thank you so much for everything else.
KAB
It appears there because on mobile the remove column doesn't appear. You may want to leave a copy of it where it is for mobile with the maxTablet class and create another copy for the desktop in another column.
