confirm page correct location to create universal email server behaviour for sending eCart email receipt?
Thread begun 7/07/2022 11:38 am by yogastudents362523 | Last modified 7/08/2022 1:35 pm by Ray Borduin | 1387 views | 4 replies |
yogastudents362523
Hello,
The checkout wizard did not create a page or code to send emails as requested.
Should I generate the code using the webassist eCart menu at the bottom of "confirm.php"?
Was surprised to see no other server behaviours on that page.
Could you confirm correct location to run your Universal Email to generate receipt to email to pujrchasers?
Thank you,
KB
I'd probably re-run the checkout wizard in a sub-folder so you can easily copy and paste the email code and the email receipt template will be generated.
yogastudents362523
Hello,
I did as suggested, but am still not getting an email.
I also tried entering a debug mode so I could see the traffic, but am seeing nothing.
It is possible I have simply pasted the code in the wrong location? I tried to use a different one as a guide.
Thank you.
I think you just have to move the email code above the redirect code... It is redirecting before the email can send. Try moving lines 379-401 up above line 371.
yogastudents362523
Thank you.
Always something stupid.
Sorry about that.
Thank you again
