Adjusting/Removing Validations from checkout.php, as located in confirm.cart.php
Thread begun 7/09/2022 1:09 pm by yogastudents362523 | Last modified 7/18/2022 6:26 am by Ray Borduin | 2344 views | 7 replies |
yogastudents362523
Hello,
I have participants from potentially all around the world, and the validations in the fields Phone, State, and Postal Code are far too restructive (presently designed for USA criteria.
Should I simply comment those three lines out in "$WAFV_Errors" in confirm_cart.php (I tried that but must in that case have made some error).
Or may I plrease know where the function definition is located, so I can try to decipher the syntax and make the adjustments?
E.g. I am not sure to what the parameters in:
$WAFV_Errors .= WAValidatePN((isset($_POST["Phone_Number"])?$_POST["Phone_Number"]:"") . "",false,true,true,4)
are referring.
I also tried using
$WAFV_Errors .= WAValidateRQ((isset($_POST["First_Name"])?$_POST["First_Name"]:"") . "",true,1);
as a template for a "required" field, but that also did not seem to work for me.
Thank you,
KB
You should be using the Server Behavior to edit the validation. That has the options in the User Interface and will prevent typos.
yogastudents362523
I used the interface to alter the validations on phone number in confirm_cart.php to:
$WAFV_Errors .= WAValidateAN((isset($_POST["Phone_Number"])?$_POST["Phone_Number"]:"") . "",false,false,true,true,"+,.()",false,4);
so it was alphanumeric and would accept blanks, '+', and a couple of others.
I also adjusted the pattern statement to ""; but that did not work. I also tried deleting it altogethe which also did not work.
I currently have the situation that when I click submit the page refuses to advance so I can insert credit card information.
Thank you.
Give me a call when you have a chance and we can go through it over the phone to make sure everything works properly.
yogastudents362523
Thank you.
Teaching rest of today, & tomorrow AM.
Will try some time tomorrow PM
Thanks again
KAB
yogastudents362523
Hello,
I got held up quite badly by a pupil of mine and could not try until Tues 5:05 pm.
I will try again Wed 10:00 am unless you send me a message otherwise.
Thank you.
We were able to correct the phone number validation in a brief screen share. Let me know if you need help with anything else.
yogastudents362523
Thank you very much indeed.
I am sincerely grateful for both your products and all your assistance.
