Uploads not resizing?
Thread begun 7/19/2022 12:40 pm by art226587 | Last modified 8/08/2022 9:57 am by Ray Borduin | 2322 views | 12 replies |
art226587
Hi, I've set all of my file uploads to resize to a 'Fixed width and height' of 2000 x 2000, but my images are not getting resized. I've attached the file here. Could you take a look and see what I might have missed? Thanks!
What size is the image you are uploading?
art226587
I've tried a couple of images larger than 2000x2000, like 3900x3900 and 4608x3456 and both just uploaded their original size.
I'll run a test here and try to reproduce it and see what is going on.
art226587
Any luck on this?
Sorry it fell off my radar and I didn't finish testing. Do you have a sample image I can use to test that didn't resize properly? That might help make sure I see the exact problem you are experiencing. I'll set up a sample now.
art226587
The attached was larger than I wanted and should have been resized to fit within 2000 x 2000.
I just tested and the image was resized properly. What version is listed in your file: webassist/file_manipulation/helperphp.php ?
Maybe you have an older version of that file? My test used version 2.10
art226587
That sounds like my issue. Mine is version 2.07. I have Data Bridge version 2.3.5 installed and used DataAssist Pages to generate this form.
If you reinstall databridge it should update the files. I've attached my version so you can upload it and see if that fixes your problem.
