Add to cart on Name of Product brings in blank
Thread begun 7/19/2022 1:33 pm by lr_leal239405 | Last modified 7/26/2022 9:10 am by Ray Borduin | 1362 views | 4 replies |
lr_leal239405
For some strange reason this
$ATC_itemName = "testing";
will not add the name of the product into the cart. However, that same exact works from other pages. AND...the below will work.
$ATC_itemDescription = "". "testing ."";// column binding
So...for some reason the '$ATC_itemName' will not work specifically on that page. As soon as I name it $ATC_Description, it will work. It is definitely in this line below (in case you ask).
$eCart1->AddToCart($ATC_AddIfIn, $ATC_RedirectIfIn, $ATC_itemID, $ATC_itemName, $ATC_itemDescription, $ATC_itemThumbnail, $ATC_itemWeight, $ATC_itemQuantity, $ATC_itemPrice);
Can you give me any ideas? Thanks.
Please attach the entire chunk of code that isn't working and I can look to see what might be wrong.
lr_leal239405
The code is below. Thanks!
You will have to debug. The name must not be set properly.
Where you have:
if ((strlen($cac_quote_new_temp_qnums_byclient2reccart->getColumnVal("part_name"))) == 2) {
$ATC_itemName = "". html_entity_decode($cac_quote_new_temp_qnums_byclient2reccart->getColumnVal("description")) ."";// column binding
} else {
$ATC_itemName = "". ($cac_quote_new_temp_qnums_byclient2reccart->getColumnVal("part_name")) ."";// column binding
add this after:
die("added name: " . $ATC_itemName);
If there is no name, then one of the lines above must be wrong when the name is set.
lr_leal239405
Thanks for this info. I found the issue.
