Universal Email not working with a https re direct?
Thread begun 7/26/2022 10:05 pm by elewis93815 | Last modified 7/28/2022 3:48 pm by Ray Borduin | 1226 views | 2 replies |
elewis93815
Hello, We've created a contact form on a website that has an SSL in place re-directing to https. When we programmed the form using Universal Email, the entire page disappeared. GoDaddy is telling us that there is a scripting issue. Can you tell me if there is a problem with using Universal Email on a site with an Active SSL on it? Thanks so much , Erick
No, there wouldn't be an issue with email on SSL. The SMTP server doesn't care if you accessed the website with SSL or not. Maybe you didn't upload all of the necessary files? Make sure you uploaded all of the webassist/email folder. If you still have issues then add this to the top of the page:
ini_set
("display_errors",1);
Usually a blank page is an error on the page with error display turned off. Turning it on may help you diagnose and fix it.
elewis93815
Thanks, I got it resolved. Not sure what happened but I removed Universal Email and re-did it and it's good to go. Thanks again
