dynamic list
Thread begun 7/30/2022 6:19 am by birdscreen398247 | Last modified 8/01/2022 7:04 pm by Ray Borduin | 904 views | 3 replies |
birdscreen398247
dynamic list
TestSelect.php
I have a select box at lines 24-35 based on a query at lines 3-7.
I have the default option to be “Select Species.”
For some reason, the select box displays blank and when I click on it, it shows the last records in the list, not the first.
I want it to show “Select Species" and then the rest of the list in alphabetical order.
How do I fix this?
Can I get a url to reproduce? I might be able to spot the problem on the live site... I think I already have FTP access.
birdscreen398247
https://pabirds.org/porc/TestSelect.php
This is probably because of NULL values in your database. When you concatenate any string with a NULL value, it will result in NULL. To avoid this, you can use the COALESCE function. The COALESCE function returns the first non-Null value.
So instead of:
SELECT CONCAT(SPNO, ' - ', CommonName) AS BirdName, SPNO FROM aou_list ORDER BY CommonName ASC
Try:
SELECT CONCAT(Coalesce(SPNO,''), ' - ', Coalesce(CommonName,'')) AS BirdName, SPNO FROM aou_list ORDER BY CommonName ASC
