Multiple record update only works once
Thread begun 8/04/2022 2:17 am by Mags | Last modified 8/09/2022 10:50 am by Ray Borduin | 1301 views | 3 replies |
Mags
Hi Ray, I have a paginated results page (200 per page) for a table that contains over 70,000 entries. My client has just tried to update all entries for a particular user by first searching for the entries, which displayed 311 results over 2 pages, then he used the select multiple checkbox on the first page of results to select them all, but when he tried to update them, they didn't update. He then tried the same thing on page 2 of the results and that did work.
I therefore thought that the issue may be with the pagination so I changed the page to display 500 results at a time so I can now see all 311 results. However when I select multiple records (either all or just a few), they aren't updating.
I tried adding a few test rows and was also able to update them successfully - the issue seems to only be happening with multi-page results.
Could you take a look for me? I've attached the page and have included further access details in the PM.
This may be a php.ini issue. There is a setting for "max_form_fields" that wouldn't allow more than that many values to be submitted at a time.
If you need help, give me a call and I'll help you track down and fix the problem.
Mags
I've checked the phpinfo (v.7.4.30) and don't have a setting for max_form_fields but I do have max_input_vars which is set to 1000 and I think is the same thing? That should be OK though as there were 311 filtered results we were trying to update. Weird thing is that even if I only select two or three of that user's un-updated records they just won't update, but I added some test rows under a different user and was able to update them no problem. When would be a good time to call - remind me if you prefer Skype, Zoom or Teams?
Contact me via skype: webassist.rborduin
I am available this afternoon (PST). I'll be running out for lunch in about an hour, but I should be around the rest of the day.
