"Validation ShowIfs" not appearing on LogIn form
Thread begun 8/15/2022 11:07 am by yogastudents362523 | Last modified 8/21/2022 11:58 am by Ray Borduin | 1029 views | 2 replies |
yogastudents362523
Hello,
I am using the forms etc. that SecurityAssist generated for a login page.
But when I make a deliberate error and use a username or email address that I know is already contained in the relevant database, the only error that displays is:
"Invalid information, please check your entries and try again."
Neither of "The value you entered for the UserName/Email Address field is already contained in our records." appears.
I really do not like to try messing around with your code in any way.
The URL concerned is in the private area. Thank you.
There was a variable name mismatch causing this issue. In your Server Validation server behavior it was using "presentersregistration" but your show if server behaviors were checking "presenters_registration". I updated it to only use "presenters_registration" and that seems to have fixed the problem.
yogastudents362523
Thank you.
