form using plug-in file and "validation if"; how to?
Thread begun 9/09/2022 6:59 am by tony | Last modified 9/09/2022 9:29 am by Ray Borduin | 656 views | 1 replies |
tony
Hello all,
I have a form that has multiple fields.
Some fields should change while filling the form based on specific field content.
I solve this using a static plug-in and the WA framework.
So, basically, some form fields are on the master form and other fields are in the static plug-in file.
But how can I handle errors?
I use the WA Server validation on the master page that contains the main form.
But how to hanle Server validation for the fields contained in the static plug-in?
I display validations errors using "validation sow if" SB.
But where should I put the errors and the various "validation show if" for the static plug-in fields?
TIA
tony
I'd have to see your pages to understand how it is working and figure out how you might do the validations. The easier solution might be to use jquery validation and client validation since that will validate the entire form.
