Fatal error: Uncaught TypeError: sizeof(): Argument #1 ($value) must be of type Countable|array,
Thread begun 10/24/2022 11:04 pm by chriswedwardson439164 | Last modified 11/01/2022 9:21 am by Ray Borduin | 9630 views | 11 replies |
I've recently moved hosting from a shared host to a VPS with PHP 8. When updating the cart the error below is returned... I'm not sure if this error is also linked to another issue as the cart no longer shows sub total and discounts. The grand total row shows only but it doesn't take into account the discounts. Any suggestions please?
Warning: Undefined property: eCart1_Definition::$Items in /home/domain/public_html/WA_eCart/WA_eCart_Definition_PHP.php on line 106
Fatal error: Uncaught TypeError: sizeof(): Argument #1 ($value) must be of type Countable|array, null given in /home/domain/public_html/WA_eCart/WA_eCart_Definition_PHP.php:106 Stack trace: #0 /home/domain/public_html/cart.php(11): WA_eCartDefinition->CartUpdate() #1 {main} thrown in /home/domain/public_html/WA_eCart/WA_eCart_Definition_PHP.php on line 106
Can I get FTP access and a url to debug this? I'm not sure what would cause it. Maybe an issue with session variables on the site not working correctly?
Okay thanks, I'll setup ftp access.
It looks like you didn't set up folder access for that account properly. I can't get in to see any files even though the credentials seem to work.
I've double checked the ftp login details provided and they appear to work okay and can access the files. Could you please check again.
It hangs when retrieving the directory listing for me in both FileZilla and Dreamweaver.
There might be an issue with the transfer mode in FileZilla so can you please follow the steps from the attached screenshot i.e use Plain FTP and use Active mode for the transfer.
Hello Ray, any update or resolution to this error please?
I'm able to get in through FTP now. How do I reproduce the error? Please include detailed steps and an explanation of what is happening vs what you want to happen so I can understand the issue.
You will need to add a product to the cart.
