update record when form value is correct?
Thread begun 10/26/2022 2:24 pm by tony | Last modified 10/26/2022 3:39 pm by Ray Borduin | 1079 views | 3 replies |
tony
Hello Ray,
I would like to update a record when a user enters the correct value in a form field in real time without reloading the page.
What is the right approach to do this with DB2?
Can I use conditions on the update trigger?
TIA
tony
You can use a hidden iframe or ajax to submit the page and it won't be visible to the user.
tony
A framework plug-in, for example?
Tony
You could use a framework plugin... There is a behavior to load plugin to div that you can submit the form and load a div that isn't visible.
