Dynamic Dropdown throws error on /ajax_wrapper.php on line 35 (with updated files)
Thread begun 10/26/2022 7:32 pm by Hernán Basile | Last modified 10/31/2022 9:03 am by Ray Borduin | 625 views | 1 replies |
Hernán Basile
This is a new laptop, recently downloaded all extensions (Sept 24 2022).
Using Data Bridge 2.3.5 and MySQLi Server Behaviors 1.0.8
I was following the tutorial here http://www.webassist.com/dreamweaver-extensions/dynamic-dropdowns and all went fine until I tested it, that's when I got the error message on ajax_wrapper.php on line 40, then I uploaded the recommended updated files on this post https://www.webassist.com/forums/posts.php?id=42125 and now I get an error on line 35 as follows:
Fatal error: require(): Failed opening required 'cGx1Z2luLXN1YmNhdGVnb3J5LnBocA==' (include_path='.:/usr/local/php74/pear') in /home/customer/www/jefferyf8.sg-host.com/public_html/webassist/framework/ajax_wrapper.php on line 35
Online page on PM
Any clues? Is this still the security block you were referring to on that post where I took the files from?
Thanks!
Hernán Basile
I just realized that uploading the requested php page from within the framework folder solved the problem. Must be that security blocking issue you mentioned before. It works now. For others facing the same issue let me explain. I was following the above tutorial on dynamic dropdowns, all was great at localhost. Once on remote site the ajax was not working. I was calling the php page named plugin-subcategories.php from its normal location on the site, which was working on localhost. But that seems not to be the case when online, so what I did was to duplicate that page (with updated links) from the current folder into the webassist/framework folder. That did the trick. Seems the included file needs to be called from that folder for some reason. Don't forget to update the links when making a copy inside the framework folder.
Keep up the great work Webassist!
