Repeat selection determined by radio input selection
Thread begun 11/28/2022 5:41 am by s.joiner74419001 | Last modified 11/29/2022 9:14 am by Ray Borduin | 1319 views | 5 replies |
s.joiner74419001
I have a multi-step form which runs across 5 pages. Page 4 has a radio input field with 6 options which are simply numbers 1-6. what ever number is selected, i would like it to determine the amount of repeats the repeat selection on the next page ( page 5 ). I will then want to use a multiple insert behaviour on the repeat selection.
I’ve tried this so far:
I applied a form data binding to use the radio input value on page 4 as the dynamic value in the repeat selection on page 5 as follows:
$wa_repeatfor = ".((isset($_POST["specify"]))?$_POST["specify"]:"") ."; // Repeat Selection 1
$wa_repeatcount = 0;
while ($wa_repeatfor) {
$wa_repeatfor--;
$wa_repeatcount++;
this causes a 500 error to the page.
Any idea what I’m doing wrong here.
I’ve attached the two pages..
Thanks in advance
I'd need FTP access and a url with steps to reproduce the issue in order to debug this one.
s.joiner74419001
OK thanks Ray see PM
Try:
$wa_repeatfor = ((isset($_POST["specify"]))?intval($_POST["specify"]):0); // Repeat Selection 1
s.joiner74419001
Hi Ray,
Thanks for this, your code update works great now.
There is another issue I have now which is with the jQuery validate plugin I’m using with the forms.
It’s basically an error placement issue with the radio input field.
Before I used the repeat selection with this I used the code below to display the errors in the correct elements below the form group
if ( element.attr( "name" ) === "title_1" ) {
error.appendTo( "#title-error" );
else if ( element.attr( "name" ) === "title_2" ) {
error.appendTo( "#title2-error" );
else if ( element.attr( "name" ) === "title_3" ) {
error.appendTo( "#title3-error" );
else if ( element.attr( "name" ) === "title_4" ) {
error.appendTo( "#title4-error" );
else if ( element.attr( "name" ) === "title_5” ) {
error.appendTo( "#title5-error" );
else if ( element.attr( "name" ) === "title_6” ) {
error.appendTo( "#title6-error" );
else {
error.insertAfter( element );
Here’s the html sample of form group 1
<div class="form-group">
….radio inputs here
<div id="title-error"></div>
</div>
So this displayed the error message nicely below each form group. ( see screenshot_a )
The reason for this is if I just let the plugin handle the error placement it gets put inside the first radio button div ( see screenshot_b )
So because the repeat selection doesn’t dynamically create the numbers for the error message element, I’m stuck with the screenshot_b.
I would also like to have each section title dynamically created too..
i.e Director 1 … Director 2 … Director 3 etc.
i'm aware this is a javascript / jquery issue.
Is this something you could help with in a support ticket?
Many thanks
Steve
Yes. I can help with that in a support ticket. Just give me a call and we can set up a time.
