Hand coding additional fields in an INSERT or UPDATE behaviour - why might this not be working?
Thread begun 12/09/2022 4:47 am by Nathon Jones Web Design | Last modified 12/09/2022 12:14 pm by Ray Borduin | 716 views | 2 replies |
I have the following hand coded INSERT behaviour on a page:
if(!isset($_SESSION["SMCinUSERID"])) {
if (isset($_POST["btnADDSTEP1"]) || isset($_POST["btnADDSTEP1_x"])) {
$InsertQuery = new WA_MySQLi_Query($csdbmysqli);
$InsertQuery->Action = "insert";
$InsertQuery->Table = "SMCuser";
$InsertQuery->bindColumn("SMCuserUSER", "s", "".((isset($_POST["EmailConfirm"]))?$_POST["EmailConfirm"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("SMCuserFIRST", "s", "".((isset($_POST["FirstName"]))?$_POST["FirstName"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("SMCuserSUR", "s", "".((isset($_POST["Surname"]))?$_POST["Surname"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("SMCuserPASS", "s", "$hashed", "WA_DEFAULT");
if (isset($_POST["savedetailsCHECK"] ) && $_POST["savedetailsCHECK"] == 1) {
$InsertQuery->bindColumn("SMCuserADD", "s", "".((isset($_POST["Address"]))?$_POST["Address"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("SMCuserADD1", "s", "".((isset($_POST["Address2"]))?$_POST["Address2"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("SMCuserCITY", "s", "".((isset($_POST["City"]))?$_POST["City"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("SMCuserREGION", "s", "".((isset($_POST["Region"]))?$_POST["Region"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("SMCuserCOUNTRY", "i", "".((isset($_POST["Country"]))?$_POST["Country"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("SMCuserZIP", "s", "".((isset($_POST["Postcode"]))?$_POST["Postcode"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("SMCuserPHONE", "s", "".((isset($_POST["Telephone"]))?$_POST["Telephone"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("SMCuserMOBILE", "s", "".((isset($_POST["Mobile"]))?$_POST["Mobile"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("SMCuserDOB", "t", "".((isset($_POST["DOB"]))?$_POST["DOB"]:"") ."", "WA_DEFAULT");
$InsertQuery->saveInSession("NEWuserID");
$InsertQuery->execute();
$InsertGoTo = "";
if (function_exists("rel2abs")) $InsertGoTo = $InsertGoTo?rel2abs($InsertGoTo,dirname(__FILE__)):"";
$InsertQuery->redirect($InsertGoTo);
This all works fine. I needed to add two new fields to this INSERT:
$InsertQuery->bindColumn("SMCuserBIRTHCITY", "s", "".((isset($_POST["BirthCity"]))?$_POST["BirthCity"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("SMCuserBIRTHCOUNTRY", "i", "".((isset($_POST["BirthCountry"]))?$_POST["BirthCountry"]:"") ."", "WA_DEFAULT");
$InsertGoTo = "";
...but it just won't save those two new fields to DB. Everything else still works (inserts) though?
Is it not possible to hand code it like this?
I've not used DW for a while and am getting all kinds of warning messages when I open up pages. Something about various elements - Recordsets, Server Behaviours, eCart, DynTextField and more - not defining the "findServerBehaviours function".
Could this be related?
Would appreciate your advice.
Thank you.
NJ
Ray, I've put the FTP details and information in the PM below. I've spent all day trying to work this out and haven't been able to work it out. Everything, bar the two new fields I've added, saves to database. Hoping you can spot what I haven't been able to. Thank you.
It is probably that your form action is still pointing to the old version of the page so your new code isn't running. Your updated code looks like it should work.
