PHP 8.x - An unidentified error occured
Thread begun 1/12/2023 1:37 am by puppons | Last modified 3/23/2023 4:38 pm by Ray Borduin | 2354 views | 9 replies |
puppons
I am developing a testing site using PHP 8.2.1 and in DW user interface I am getting an error with recordsets.
If I click on "test" while creating the recordset I get "An unidentified error occured" message (see waerror1.JPG).
The recordset is created, but then I am getting the same error in the bindings panel (see waerror2.JPG).
I juste downloaded and reinstalled Data Bridge extension,deleted local and remote WA files and folders and reapplied serve behaviors.
I get the problem with PHP 8.x versions, with 7.x it's working fine.
Do you have nay suggestion?
Thanks, Guido.
Thanks, Guido.
This is an issue with your testing server settings in dreamweaver... usually the website URL is wrong. If you send me a screenshot of those settings I may be able to spot the problem.
puppons
Here are the testing server settings screenshots.
Many thanks
It looks correct to me... can you send me your FTP password in the private area? I'll set up the same site definition and see if I can reproduce the error to debug it.
puppons
Ok, FTP and DB credential written in private area.
Thanks, Guido
puppons
Well, I don't exactly know why, but it seems that today everything is working fine.
I'll check it better and in case of problems I'll write here again.
Many thanks, Guido.
puppons
Same problam again
I have the same problem again, on a different site/domain.
Will write in private...
If you send me details so I can reproduce the issue, then I can try to help you debug it.
puppons
Here are credential to try to recreate the problem
I had to update the extension to address this issue. Please re-install and it should be fixed.
