Having issue with PHP Version 8.2 ( Deprecated: Creation of dynamic property WA_MySQLi_RS )
Thread begun 1/18/2023 11:19 pm by info420411 | Last modified 1/20/2023 8:58 am by Ray Borduin | 3351 views | 2 replies |
info420411
I switch from PHP 7.4 to 8.2
I install the latest version of MySWLi Server Behavior
I got this errors from rsobj.php
Deprecated: Creation of dynamic property WA_MySQLi_RS::$Columns is deprecated in C:\xampp\htdocs\funkateer\webassist\mysqli\rsobj.php on line 7
Deprecated: Creation of dynamic property WA_MySQLi_RS::$Connection is deprecated in C:\xampp\htdocs\funkateer\webassist\mysqli\rsobj.php on line 8
Deprecated: Creation of dynamic property WA_MySQLi_RS::$CurrentPage is deprecated in C:\xampp\htdocs\funkateer\webassist\mysqli\rsobj.php on line 9
Deprecated: Creation of dynamic property WA_MySQLi_RS::$CrossSiteProtect is deprecated in C:\xampp\htdocs\funkateer\webassist\mysqli\rsobj.php on line 10
Deprecated: Creation of dynamic property WA_MySQLi_RS::$Debug is deprecated in C:\xampp\htdocs\funkateer\webassist\mysqli\rsobj.php on line 11
Deprecated: Creation of dynamic property WA_MySQLi_RS::$EncryptionAlgorithm is deprecated in C:\xampp\htdocs\funkateer\webassist\mysqli\rsobj.php on line 12
Deprecated: Creation of dynamic property WA_MySQLi_RS::$EncryptionKey is deprecated in C:\xampp\htdocs\funkateer\webassist\mysqli\rsobj.php on line 13
Deprecated: Creation of dynamic property WA_MySQLi_RS::$EncryptionMode is deprecated in C:\xampp\htdocs\funkateer\webassist\mysqli\rsobj.php on line 14
Deprecated: Creation of dynamic property WA_MySQLi_RS::$ErrorMessage is deprecated in C:\xampp\htdocs\funkateer\webassist\mysqli\rsobj.php on line 15
Deprecated: Creation of dynamic property WA_MySQLi_RS::$FilterValues is deprecated in C:\xampp\htdocs\funkateer\webassist\mysqli\rsobj.php on line 16
Deprecated: Creation of dynamic property WA_MySQLi_RS::$Index is deprecated in C:\xampp\htdocs\funkateer\webassist\mysqli\rsobj.php on line 17
Deprecated: Creation of dynamic property WA_MySQLi_RS::$IsStored is deprecated in C:\xampp\htdocs\funkateer\webassist\mysqli\rsobj.php on line 18
Deprecated: Creation of dynamic property WA_MySQLi_RS::$LastRow is deprecated in C:\xampp\htdocs\funkateer\webassist\mysqli\rsobj.php on line 19
Deprecated: Creation of dynamic property WA_MySQLi_RS::$MaxRows is deprecated in C:\xampp\htdocs\funkateer\webassist\mysqli\rsobj.php on line 20
Deprecated: Creation of dynamic property WA_MySQLi_RS::$Name is deprecated in C:\xampp\htdocs\funkateer\webassist\mysqli\rsobj.php on line 21
Deprecated: Creation of dynamic property WA_MySQLi_RS::$NextPage is deprecated in C:\xampp\htdocs\funkateer\webassist\mysqli\rsobj.php on line 22
Deprecated: Creation of dynamic property WA_MySQLi_RS::$PageParam is deprecated in C:\xampp\htdocs\funkateer\webassist\mysqli\rsobj.php on line 23
Deprecated: Creation of dynamic property WA_MySQLi_RS::$PageNum is deprecated in C:\xampp\htdocs\funkateer\webassist\mysqli\rsobj.php on line 24
Deprecated: Creation of dynamic property WA_MySQLi_RS::$ParamTypes is deprecated in C:\xampp\htdocs\funkateer\webassist\mysqli\rsobj.php on line 25
Deprecated: Creation of dynamic property WA_MySQLi_RS::$ParamValues is deprecated in C:\xampp\htdocs\funkateer\webassist\mysqli\rsobj.php on line 26
Deprecated: Creation of dynamic property WA_MySQLi_RS::$ParamDefaults is deprecated in C:\xampp\htdocs\funkateer\webassist\mysqli\rsobj.php on line 27
Deprecated: Creation of dynamic property WA_MySQLi_RS::$Prepared is deprecated in C:\xampp\htdocs\funkateer\webassist\mysqli\rsobj.php on line 28
Deprecated: Creation of dynamic property WA_MySQLi_RS::$PrevPage is deprecated in C:\xampp\htdocs\funkateer\webassist\mysqli\rsobj.php on line 29
Deprecated: Creation of dynamic property WA_MySQLi_RS::$RemoveParams is deprecated in C:\xampp\htdocs\funkateer\webassist\mysqli\rsobj.php on line 30
Deprecated: Creation of dynamic property WA_MySQLi_RS::$Results is deprecated in C:\xampp\htdocs\funkateer\webassist\mysqli\rsobj.php on line 31
Deprecated: Creation of dynamic property WA_MySQLi_RS::$StartLimit is deprecated in C:\xampp\htdocs\funkateer\webassist\mysqli\rsobj.php on line 32
Deprecated: Creation of dynamic property WA_MySQLi_RS::$SkipRows is deprecated in C:\xampp\htdocs\funkateer\webassist\mysqli\rsobj.php on line 33
Deprecated: Creation of dynamic property WA_MySQLi_RS::$StartRow is deprecated in C:\xampp\htdocs\funkateer\webassist\mysqli\rsobj.php on line 34
Deprecated: Creation of dynamic property WA_MySQLi_RS::$Statement is deprecated in C:\xampp\htdocs\funkateer\webassist\mysqli\rsobj.php on line 35
Deprecated: Creation of dynamic property WA_MySQLi_RS::$Table is deprecated in C:\xampp\htdocs\funkateer\webassist\mysqli\rsobj.php on line 36
Deprecated: Creation of dynamic property WA_MySQLi_RS::$TotalPages is deprecated in C:\xampp\htdocs\funkateer\webassist\mysqli\rsobj.php on line 37
Deprecated: Creation of dynamic property WA_MySQLi_RS::$TotalRows is deprecated in C:\xampp\htdocs\funkateer\webassist\mysqli\rsobj.php on line 38
Can you help?
Best Frank
Deprecated means "This still works, but it won't in the future"
The simplest solution is to turn off deprecated messages in your php settings and then you can just ignore this problem.
However, I did just update the files referenced in the error and fixed it, so you could also reinstall the extension and re-apply the recordset and the code will be updated to correct the problem.
info420411
it works!
thank you very very much!
I wish you a nice weekend
Best Frank
