debug codes
Thread begun 1/19/2023 11:08 am by jo271221 | Last modified 1/23/2023 6:17 pm by Ray Borduin | 647 views | 1 replies |
jo271221
debug codes
I thought it would be a great resource to have all the debug codes in one post. Is that possible and an option?
Insert
Update
Search
Results
Any other notes...
What do you mean by debug code? Can you give me an example?
You can turn on the Debug attribute for recordsets or query objects to see the actual error if you see:
"There is an error in your SQL syntax."
Then you can add:
$Recordset1->Debug = true;
before the line:
$Recordset->execute();
