Data Bridge V2 Form/ Email without template
Thread begun 1/20/2023 8:43 am by info420411 | Last modified 1/23/2023 11:25 am by Ray Borduin | 1256 views | 3 replies |
info420411
Hello
I am a new user of Data Bridge V2. I wanted to make with "insert Form" a contact form with email dispatch. That goes also quite well but I would like to select with "Form Function" no Template. I want to send a very simple classic mail.
What do I have to do here? I have found nothing in the instructions.
You shouldn't need to use a template. If you want to give me a call I can do screen sharing and help you through it your first time.
info420411
Hi Ray and thank you
I am not proficient in the English language. I use Google Translator for communication :-D That helps a lot.
If you provide me with simple screenshots and text it will definitely help me.
A simple example would be enough for me. Standard contact form which generates a normal email.
Thank you very much.
You can just create a contact form manually and apply the "Send Email Message" server behavior. I can't do screenshots for you, but if you want to come to a zoom meeting with me I can walk you through it.
