Send Email how to insert fieds into the body of the email
Thread begun 1/23/2023 10:56 am by msmoose2400634 | Last modified 1/27/2023 11:25 am by Ray Borduin | 1817 views | 5 replies |
msmoose2400634
I have a update form that works correctly, I am trying to add the "Send Email" from the webassist dropdown and when I get to the Email Body, I do not understand how to add the fields I want to the email. I have attached one document.
Just click "OK" and the email body file will be created as a .php file and it will be opened in dreamweaver for you to edit and add whatever you need.
msmoose2400634
There is a "Finish" button that I pressed but no .php file opened up for me in dreamweaver
Please attach the page where you have the email server behavior applied so I can take a look.
msmoose2400634
Thank you Ray, I have the update record form working, it is sending out the correct email plus navigating to the correct page. What I don't know how to do is put the dynamic data is the body of the email. When I put a recordset in the email page I get an error message when I take out the recordset everything works properly except I don't have my dynamic data in the email. I have attached the email the is being sent. Karen
You can add the recordset to the page where the email server behavior is applied.
To access and use it in the email body you just have to add code to the top of the page like:
global $Recordset1;
