Add "active" class
Thread begun 1/27/2023 10:34 pm by Raza | Last modified 2/14/2023 8:16 am by Ray Borduin | 2725 views | 8 replies |
Raza
Add "active" class
hello,
how are you? hope doing well. I want ask how to add Bootstrap class "active" to dynamic menu? I am attaching the code file
regard
It looks like you are already trying to with:
<?php if (stripos($_SERVER['REQUEST_URI'],'index.php') !== false) {?>active<?php } ?>
Where else did you want to add it? or what isn't working the way you want? I would think code similar to the code you have would work.
Raza
its applied on all menu
Maybe try:
<a class="nav-link <?php if (stripos($_SERVER['REQUEST_URI'],'index.php?name='.$Recordset1->getColumnVal("name")) !== false) {?>active<?php } ?>" aria-current="page" href="index.php?name=<?php echo($Recordset1->getColumnVal("name")); ?>">
</a>
Raza
sorry for late. its works Thanks but detail page showing same in each page I don't whats wrong in fact code is fine I am sending demo and code
It might be an issue with your .htaccess file not passing the correct name.... ad this to your page:
Showing: <?php echo($_GET["page"]); ?>
If the name doesn't change, then it is probably an issue with your .htaccess
Raza
here is .htaccess code
RewriteEngine On
RewriteRule ^([a-zA-Z0-9-]+)?$ index.php?name=$1
That looks correct. I may need to help with this in a premier support ticket. I need to debug your code live to make sure I understand and can fix the problem and the forums won't allow that.
Raza
I will sort out it on my own
