Security Assist "Please enter a value" error
Thread begun 2/04/2023 7:09 am by yogastudents362523 | Last modified 2/05/2023 12:35 pm by Ray Borduin | 2754 views | 14 replies |
yogastudents362523
Hello,
I have just used SecurityAssist to make its family of pages.
The login page keeps giving me the above error, and I am not sure why.
"Please enter a value".
The entries in the database being checked against were manually pre-entered, in case that makes a difference.
And in case it helps, here is the code generated in what I think is the appropriate part:
I will p;ut the URL to the relevant page in the private area.
Thank you.
if ((isset($_POST["LogIn_submit"]) || isset($_POST["LogIn_submit_x"]))) {
$WAFV_Redirect = "".($_SERVER["REQUEST_URI"]) ."?invalid=true";
$_SESSION['WAVT_participantslogin_Errors'] = "";
if ($WAFV_Redirect == "") {
$WAFV_Redirect = $_SERVER["PHP_SELF"];
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateRQ((isset($_POST["Log_In_group_UserName"])?$_POST["Log_In_group_UserName"]:"") . "",true,1);
$WAFV_Errors .= WAValidateRQ((isset($_POST["Log_In_group_2_Password"])?$_POST["Log_In_group_2_Password"]:"") . "",true,2);
$WAFV_Errors .= WAValidateEL((isset($_POST["Log_In_group_2_Password"])?$_POST["Log_In_group_2_Password"]:"") . "",6,500,true,3);
if ($WAFV_Errors != "") {
PostResult($WAFV_Redirect,$WAFV_Errors,"participantslogin");
Where is the error on the page. Is this for the username or password? Does it happen before or after you click the submit button? Please attach the full page so I can take a look.
yogastudents362523
Hello,
I am not certain where the error on the page is.
It was created by Security Assist.
The warning message appears before I have hit the submit button.
I attach the page, Thank you
Between lines 5 and 6 add:
@session_start();
yogastudents362523
Thank you,
KAB
yogastudents362523
Hi
Spoke a bit too soon.
Now the page that it should direct me to is refusing to accept the signed-in status.
I am redirected away.
I have attached it.
Thank you.
KAB
Please attach a copy of the file: /webassist/security_assist/helper_groups_rules.php
I can look and see if the access rule is set up properly.
yogastudents362523
Thank you
Attached
K
It all looks right... we may need to do a screen share to debug. I'm sure I can figure it out quickly if I have access to the code. Are you sure you uploaded this file?
yogastudents362523
Just to be sure, I reuploaded it.
Checked the contents online and it is good.
But now ... ... ... the login file has taken to saying "Please enter a value" again!!
Sorry!
KAB
