Hosting changed us to CentOS7 and VPS Gen 4
Thread begun 2/09/2023 5:58 am by lr_leal239405 | Last modified 2/22/2023 2:44 pm by Ray Borduin | 2348 views | 5 replies |
lr_leal239405
PHPMailer doesn't work any longer after Hosting changed us to CentOS7 and VPS Gen 4 server
The servers hosting our website were upgraded from CentOS6 to CentOS7 and to VPS Gen4 from Gen3. After that anything using PHPMailer stopped working properly and I see a message that says "Language string failed to load: tls". Can you tell me where to make the change in the PHPMailer code so that it continues working? I can attach the file. Thanks for your help witht his.
lr_leal239405
Now even Webassist's emails stopped working. (a couple of days after the server move by godaddy).
I think I will need some tech support on this.
lr_leal239405
So, my question now is really.... do you know anything about Gen4 (CentOS 7) servers on godaddy not deliverying phpmailer email any longer? Thanks.
Godaddy is notorious for difficulty with sending emails. It might be as simple as the subject containing words that makes godaddy think it is spam so it won't send. It will work, but it can be tricky to track down why it isn't being delivered.
lr_leal239405
It turned out that it wouldn't send emails because the server itself has a setting in WHM (the new Cpanel) for SMTP email that you can change the bypass the godaddy server. Thanks for your help.
What is the setting name and what should the value be just in case someone else has this problem?
