Cannot get email to send in my webpage's email form
Thread begun 2/12/2023 8:16 am by randyrie405335 | Last modified 2/22/2023 3:04 pm by Ray Borduin | 1960 views | 6 replies |
randyrie405335
I've placed a tab group on a php webpage that iframes in a history and a feedback form but neither work as expected. The history form places the collected data into the MySQL database but does NOT send out the email that I inserted into the page (via the Webassist Email menu item). Also, the Feedback form does not send out the email but returns with a "page not found" error.(I think I need a way to keep the action on the page?)
Please visit https://www.rjrwebz.com/rfl/contribute.php and see if you can determine what I've done wrong so that neither forms on the page work. I'm ending the webpage and the two include form pages for your review.
Hopefully you can spot why this isn't working? I can give you ftp access if needed.
(I'm using a macbook, macOS 11.7.2 (Big Sur), Xampp with php v7.3.11. I've also tried fixing this by remaking everything on a Dell Inspiron PC running Windows 11 and Xampp)
Thank you very much in advance for any help or advice.
Randy Riesterer
Remove the "action" attribute of your forms. That will make it automatically post to itself, which is where your code to process the form submission is located.
The action page is the only page that will get the form data. Your form currently posts to the main page and it doesn't have any of the insert or email code on it.
randyrie405335
Email and Insert still fail
Thanks Ray for your quick response.
I took your advice and rebuilt the History form with no action listed and now it does enter its data into the database.However, the feedback tab's email form will not load and displays no error even though I added the default=true to the queryobj.php page I've rebuilt the form several times but it always fails to load and no error is displayed.
If you update your queryobj.php page and change the setting:
->Debug = false;
->Debug = true;
It should give you a better error we can use to figure out what is going on.
Give me a call using the number at the bottom of this website, or text me through Skype: webassist.rborduin
randyrie405335
I'll give you a call now.
