...code that is locked by a template or translator. Error?
Thread begun 2/16/2023 3:18 am by SCar87011738 | Last modified 2/22/2023 10:57 am by Ray Borduin | 1173 views | 3 replies |
SCar87011738
Hello all,
I'm not using templates at all, but I receive ther error message "...code that is locked by a template or translator. Your editing will be rejected (translated from italian; not sure it's correct)".
I trying to add a simple CallJS behaviour to the Body tag but I get this message and I can't add it using the DW behaviour window.
How can I solve?
I can add the code manually, but I would like to know what is causing the problem.
I already cleared the DW cache.
TIA
tony
Please attach the page that has the error. I should be able to find the problem.
SCar87011738
Hi Ray,
after some work on the page the error disappeared.
I really don't know why.
Is there a place to look at, in the code?
I'll be back here when the problem re-occurs.
Thanks, anyway.
Tony
Usually it would mean there is a template comment in the code. If it happens again, include the file in a post and I can reproduce and figure out the issue.
