Count error all of a sudden
Thread begun 3/20/2023 1:43 pm by LionsMane | Last modified 3/28/2023 10:54 am by Ray Borduin | 1672 views | 6 replies |
LionsMane
My site has been working fine, and suddenly now I'm getting this error when trying to build an recordset. PHP is 7.4, nothing has changed in the code. Thoughts? Here's the error: Warning: sizeof(): Parameter must be an array or an object that implements Countable in /homepages/10/d169853639/htdocs/webassist/mysqli/rsobj.php on line 206
Download and install the latest version of the extension. Most likely the rsobj.php file has been updated to correct this issue.
LionsMane
Errors
This post has been deleted.
LionsMane
still an issue
OK, that solved the error, but now all the HTML markup in the dynamic content is showing as HTML/plain text instead of actual renderable HTML???
LionsMane
LionsMane
I found a reference to where I have to make the RS reference $Recordset->getColumnVal("column",false); including the ",false" designation. I have a LOT of pages on this site! I have to manually do this to ever page?????? I've never had to before??
The new version has built in cross site scripting protection. You could turn it off globally in the rsobj.php file as well and you wouldn't have to update your pages individually, but you open up the potential for cross site scripting (potentially depending on how you are allowing user input throughout the site).
