Error with MySQLi recordset
Thread begun 4/05/2023 4:47 pm by sandy170299 | Last modified 4/06/2023 1:02 pm by Ray Borduin | 2127 views | 4 replies |
sandy170299
There's no code on the page, except for the recordset. I can connect to the DB, and create a query without an issue, but this is what I'm receiving when I browse the page:
Fatal error: Array and string offset access syntax with curly braces is no longer supported in C:\xampp\htdocs\ElectionTrends\webassist\mysqli\rsobj.php on line 168
I am using the latest version of the MySQLi extension, and I'm running PHP version: 8.2.0 on localhost.
Thank you.
sandy170299
Okay, I was able to solve that error by replacing if ($paramTypes{$x} == 'i') {
with if ($paramTypes[$x] == 'i') {
But now I'm getting a ton of other errors:
_________________________________________________________________________________________________________________
Deprecated: Creation of dynamic property WA_MySQLi_RS::$Connection is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\mysqli\rsobj.php on line 9
Deprecated: Creation of dynamic property WA_MySQLi_RS::$CurrentPage is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\mysqli\rsobj.php on line 10
Deprecated: Creation of dynamic property WA_MySQLi_RS::$Debug is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\mysqli\rsobj.php on line 11
Deprecated: Creation of dynamic property WA_MySQLi_RS::$EncryptionAlgorithm is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\mysqli\rsobj.php on line 12
Deprecated: Creation of dynamic property WA_MySQLi_RS::$EncryptionKey is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\mysqli\rsobj.php on line 13
Deprecated: Creation of dynamic property WA_MySQLi_RS::$EncryptionMode is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\mysqli\rsobj.php on line 14
Deprecated: Creation of dynamic property WA_MySQLi_RS::$FilterValues is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\mysqli\rsobj.php on line 15
Deprecated: Creation of dynamic property WA_MySQLi_RS::$Index is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\mysqli\rsobj.php on line 16
Deprecated: Creation of dynamic property WA_MySQLi_RS::$LastRow is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\mysqli\rsobj.php on line 17
Deprecated: Creation of dynamic property WA_MySQLi_RS::$MaxRows is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\mysqli\rsobj.php on line 18
Deprecated: Creation of dynamic property WA_MySQLi_RS::$Name is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\mysqli\rsobj.php on line 19
Deprecated: Creation of dynamic property WA_MySQLi_RS::$NextPage is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\mysqli\rsobj.php on line 20
Deprecated: Creation of dynamic property WA_MySQLi_RS::$PageNum is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\mysqli\rsobj.php on line 21
Deprecated: Creation of dynamic property WA_MySQLi_RS::$ParamTypes is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\mysqli\rsobj.php on line 22
Deprecated: Creation of dynamic property WA_MySQLi_RS::$ParamValues is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\mysqli\rsobj.php on line 23
Deprecated: Creation of dynamic property WA_MySQLi_RS::$ParamDefaults is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\mysqli\rsobj.php on line 24
Deprecated: Creation of dynamic property WA_MySQLi_RS::$Prepared is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\mysqli\rsobj.php on line 25
Deprecated: Creation of dynamic property WA_MySQLi_RS::$PrevPage is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\mysqli\rsobj.php on line 26
Deprecated: Creation of dynamic property WA_MySQLi_RS::$QueryString is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\mysqli\rsobj.php on line 27
Deprecated: Creation of dynamic property WA_MySQLi_RS::$Results is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\mysqli\rsobj.php on line 28
Deprecated: Creation of dynamic property WA_MySQLi_RS::$StartLimit is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\mysqli\rsobj.php on line 32
Deprecated: Creation of dynamic property WA_MySQLi_RS::$StartRow is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\mysqli\rsobj.php on line 33
Deprecated: Creation of dynamic property WA_MySQLi_RS::$Statement is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\mysqli\rsobj.php on line 34
Deprecated: Creation of dynamic property WA_MySQLi_RS::$Table is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\mysqli\rsobj.php on line 35
Deprecated: Creation of dynamic property WA_MySQLi_RS::$TotalPages is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\mysqli\rsobj.php on line 36
Deprecated: Creation of dynamic property WA_MySQLi_RS::$TotalRows is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\mysqli\rsobj.php on line 37
Deprecated: Creation of dynamic property WA_Include::$Start_Dir is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\framework\framework.php on line 5
Deprecated: Creation of dynamic property WA_Include::$File is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\framework\framework.php on line 6
Deprecated: Creation of dynamic property WA_Include::$BaseName is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\framework\framework.php on line 7
Deprecated: Creation of dynamic property WA_Include::$Reset is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\framework\framework.php on line 8
Deprecated: Creation of dynamic property WA_Include::$Added is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\framework\framework.php on line 9
Deprecated: Creation of dynamic property WA_Include::$Dir is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\framework\framework.php on line 11
Deprecated: Creation of dynamic property WA_Include::$Body is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\framework\framework.php on line 12
Deprecated: Creation of dynamic property WA_Include::$Head is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\framework\framework.php on line 13
Deprecated: Creation of dynamic property WA_Include::$HTML is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\framework\framework.php on line 14
Deprecated: Creation of dynamic property WA_Include::$Title is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\framework\framework.php on line 15
Deprecated: Creation of dynamic property WA_Include::$Above is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\framework\framework.php on line 16
Deprecated: Creation of dynamic property WA_Include::$Links is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\framework\framework.php on line 17
Deprecated: Creation of dynamic property WA_Include::$Styles is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\framework\framework.php on line 18
Deprecated: Creation of dynamic property WA_Include::$DocType is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\framework\framework.php on line 19
Deprecated: Creation of dynamic property WA_Include::$Content is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\framework\framework.php on line 20
Deprecated: Creation of dynamic property WA_Include::$MetaTags is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\framework\framework.php on line 21
Deprecated: Creation of dynamic property WA_Include::$MetaKeywords is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\framework\framework.php on line 22
Deprecated: Creation of dynamic property WA_Include::$MetaDescription is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\framework\framework.php on line 23
Deprecated: Creation of dynamic property WA_Include::$MetaContentType is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\framework\framework.php on line 24
Deprecated: Creation of dynamic property WA_Include::$MetaKeywords_Content is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\framework\framework.php on line 25
Deprecated: Creation of dynamic property WA_Include::$MetaDescription_Content is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\framework\framework.php on line 26
Deprecated: Creation of dynamic property WA_Include::$MetaContentType_Content is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\framework\framework.php on line 27
Deprecated: Creation of dynamic property WA_Include::$EditableRegions is deprecated in C:\xampp\htdocs\ElectionTrends\webassist\framework\framework.php on line 28
___________________________________________________________________________________________________________________
The page does load, and the search form does work, but I don't know what to do about all these errors. If things are working, can they just be hidden, or is that a really bad idea?
Thanks.
If you reinstall databridge, then the next time you update a server behavior that uses the files with messages will be updated and fix the problem.
You could also just turn off deprecated messages in your php.ini file and these messages won't effect the functionality of the page.
sandy170299
The errors are still there, even after updating the plugin and clearing my cache, and I won't have access to php.ini on the server.
I think if I do it just through code on the pages that are causing errors, it will be okay. Just to clarify, this will not affect performance of the page or the code from running properly?
Thanks.
The error is in a framework builder file... so you would have to add a plugin or update a framework builder server behavior to get it overwritten. I'll attach the latest copy.
