Emails won't send
Thread begun 4/14/2023 5:11 am by Sweens | Last modified 4/18/2023 4:25 pm by Ray Borduin | 2488 views | 12 replies |
Sweens
Emails won't send
Hi Ray
Been trying to modify a contact form that works without success.
As a test, I've created a really simple form - but the email isn't sent.
I'm using the latest version of the extension, so can't fathom it out.
Files attached
Cheers
Chris
Try creating a blank page that sends an email with:
$to
= 'nobody@example.com';
$subject = 'the subject';
$message = 'hello';
$headers = 'From: webmaster@example.com' . "\r\n" .
'Reply-To: webmaster@example.com' . "\r\n" .
'X-Mailer: PHP/' . phpversion();
mail($to, $subject, $message, $headers);
If that doesn't send, then that implies it is an issue with your SMTP server and not the code. If that works, then I'd probably need FTP access and a url to look at the page and test it to see why it isn't working on your page.
Sweens
Thanks Ray
That worked - came through immediately
Cheers
Chris
What is the url to the page I'm looking at?
Sweens
Thanks Ray
See pm
That page doesn't seem to exist on the server.
Sweens
Duh! Sorry
pm
Can you put up the test page that worked somewhere? I want to take a look at that too.
Sweens
Hi Ray
pm
I'm not sure why but I had to manually update a configuration setting by adding the line:
$Email->Mailer->UseSendmailOptions = false;
That seems to have fixed it. You will probably have to do that on other email server behaviors for this site.
