plugin not updating db
Thread begun 4/24/2023 5:20 am by Jamie | Last modified 4/28/2023 9:30 am by Ray Borduin | 1067 views | 3 replies |
Jamie
Hey Ray
Have tried to manually create a plugin.
The 'plugin' (slideshow2_update/.php) is an update page and has been added to a page that lists results from another table in the db. When I update the plugin it is supposed to redirect to testimonial_results.php (the page that the plugin is instaled on) but it redirects to page_contents_update for some reason.
Also, it is not updating the database either.
The page being plugged in works on its own
Both pages are attached
Cheers
Jamie
I think I'd like to debug this with you in a screen sharing session. I can't find a reference to "page_contents_update" anywhere, so that is the first puzzle I'd like to figure out.
Jamie
So have redone this on my home set up and it's working fine. The only thing that isn't working is that on the plugged in page after update needs to be refreshed to relefct any changes
You could either refresh the whole page, or use the webassist behavior "Load plugin to div" to reload just the plugin.
