Internal Server Error when submitting credit card info
Thread begun 4/24/2023 9:29 am by eric284736 | Last modified 5/02/2023 12:10 pm by Ray Borduin | 2425 views | 12 replies |
eric284736
Hi Ray,
I am getting a 500 internal server error when submitting the credit card info. Could you take a look?
Thanks,
Eric
eric284736
PM
I'm not seeing the 500 error when I try to check out on the site.
eric284736
Once you enter the CC info and click submit it gives me the internal server error.
Thanks,
Eric
The FTP information provided doesn't seem to work for me. Do you have IP restrictions that might be keeping me out?
eric284736
PM
I have narrowed down the error to your line of code with:
\Stripe\Charge::create();
I've scoured the web and your code looks correct, so I can only assume you may need to update your Stripe installation on the server.
I added debug code to help you see and debug the error. If you comment out line 62 you will see your error, but with line 62 the line runs, so that means the code with the error is on line 63.
eric284736
Thanks Ray!!!
eric284736
pm
I can try to help. I'd start by going back to their documentation and doing a test transaction page without the cart. Integrating the cart should be easy once the stripe code itself is working. Let's meet on Tuesday next week and do screen sharing and I'll help.
